1200n or 1200s ? (new info now!) |
kammiz
Norwegisch
how can i tell if a 1200 engine i have is 1200n or 1200s ?
i have looked at the motor and on the engine block this was typed:
21B
33
78
2193010 (Edit 05/09; 12*2193010 is correct, i removed some dirt..
on the engine head this was typed:
33
90088353
does this say if the engine is 1200n or 1200s ? please help me.
04.09.07 20.47 |
olyschrauber
Dauerschrauber
Herkunft: Maerkischer Kreis
Hello kammiz,
on the left side of the engine is the engine-number who begins with "12S-" or "12-" or "12S*" or "12*". When there is a "12S" you have a S-Engine, when there is only a "12" its a N-Engine.
Hope i have help you...
Greetings Lutz
I´m sorry about my very bad "school-english"
__________________ Wer lange schraubt, glaubt noch immer ans ZIEL!!!
04.09.07 21.07 |
66er Rallye unregistriert
04.09.07 21.20 |
kammiz
Norwegisch
when you say left side, you mean the drivers side of the car? i will check this later today, but i did not see any more stampings.
05.09.07 08.35 |
Lehrbua
Alpenglüher
Herkunft: The Alps
Yes, left side is driver side. Usually you take about left or right in the driving direction. (forward)
05.09.07 09.14 |
knorburg
Herkunft: DE
Hvis der på den venstre side et stjerne, ha' du et "s" maskin
05.09.07 10.18 |
das kann ich bestätigen
05.09.07 10.21 |
kammiz
Norwegisch
knorburg says if there is a star on the left side of the engine i have a S engine. is this correct?
05.09.07 11.21 |
LSman unregistriert
Hi Kammiz,
no, that`s not correct: A star means it`s a 12 engine with 55 hp, without the star it has 52 hp. A 12S must show the stamp "12S-..."
This is simmilar to the engine type 11: Without a star it has 45 hp and with it has 50 hp.
Kind regards,
05.09.07 12.42 |
kammiz
Norwegisch
ok. then i will go look for the 12s- stamping later today! :D
05.09.07 13.01 |
knorburg
Herkunft: DE
unskyld kammiz, men jeg viste det ikke bedre
- håber du bl'ir mere heldig med din videre søgning.
vh
05.09.07 14.14 |
kammiz
Norwegisch
Original von knorburg
vh |
that is ok.. ;) i guess english would be the preferred language.. not many danish people here i guess? ;)
05.09.07 17.32 |
kammiz
Norwegisch
on the left side of the engine it says 12*2193010, not just 2193010. i removed some dirt..
there was no "-".. not 12*-2193010, but just 12*2193010.
so 12* means this is a 55hp 12n engine?
05.09.07 17.34 |
LSman unregistriert
Hi Kammiz,
yes, it is a 55 hp engine. It was built for the Kadett C from the '76 model up to the '79 one. The following Kadett D was available with both 12-type engines too, but the normal version has 53 hp and the 12S has 60 hp as usual.
The Ascona and Manta B series were availbale with the 12* engine, too.
Kind regards,
05.09.07 21.26 |
kammiz
Norwegisch
then i will have to look for another engine ;) i want the 12s engine.
06.09.07 06.13 |
Original von kammiz
soo you are making a POWERkadett
i got hold of a 12s engine today, with 61000km since new ...
the car was scrapped of a 15year old kid for the fun of it
, luckily he never got it running (thanks to his father who took the ignitiondistributor so the wouldent drive off)
06.09.07 16.08 |
kammiz
Norwegisch
Original von nobrakes
Original von kammiz
, luckily he never got it running (thanks to his father who took the ignitiondistributor so the wouldent drive off) |
i think you should use your 1100sr engine and sell the 1200s to me
06.09.07 17.41 |
kammiz
Norwegisch
where should the star that indicates it is a 12n with 55 hp be? because, i finally got at 12s engine, but where the enginenumber is it says 12s* and then the engine number.
somebody told me the star after 12 or 12s is just to indicate that the following numbers are the engine number.
should the star on the 12n 55hp be somewhere else on the engine block?
25.09.07 08.46 |
