Kadett B Forum » Alles zum Kadett B » Motoren » I need some 11S information! » Hallo Gast [Anmelden|Registrieren]
Zum Ende der Seite springen I need some 11S information!
 I need some 11S information! Cassius 06.08.05 14.57
 RE: I need some 11S information! DasWiesel 06.08.05 17.59
 RE: I need some 11S information! Cassius 06.08.05 18.22
 RE: I need some 11S information! DasWiesel 07.08.05 12.42
 RE: I need some 11S information! Cassius 07.08.05 12.59
 RE: I need some 11S information! DasWiesel 07.08.05 13.07
 RE: I need some 11S information! DasWiesel 07.08.05 14.55
 RE: I need some 11S information! Cassius 07.08.05 15.47
 RE: I need some 11S information! DasWiesel 07.08.05 16.09
 RE: I need some 11S information! Cassius 07.08.05 18.10
 RE: I need some 11S information! 1000er 08.08.05 19.59
Cassius
I need some 11S information! Auf diesen Beitrag antworten Zitatantwort auf diesen Beitrag erstellen Diesen Beitrag editieren/löschen Diesen Beitrag einem Moderator melden       Zum Anfang der Seite springen
First of all, my german language skills are pretty poor but i hope you won't get too mad at me for typing in english smile
After a little accident last week the engine in my Kadett C broke down, it was a 12S but since I want to get out on the roads soon again the engine swap to a C20NE will have to wait a little longer..
BUT! I did have an old 11S engine laying around so I pulled it back home to the garage. Well there I thought, why not put the best parts of these two engines together! And that means the 12S head (1mm larger inlet valves) the 12S carburator, I think the 11S uses the 30 PDSI carb, right? And then possibly the 12S camshaft, however (and here's the real question) Is there any difference between these two cams?
I hope to get about the same power out of the 11S engine that the 12S engine had. Do you think that is possible with a little "tuned" headports, especially the exhaust side, and a higer compressionratio? The 11S has 8,5:1 right? I thought I'd run 10:1 or even 10,5:1!
Also, another 35PDSI carb shouldn't be a problem to find, but how much can I gain by running two 35 PDSI carbs on this engine? I also guess I'll have to change jets if I do this, does anyone have any idea of wich jets would be good? Everything over 60PS is a bonus, but more power = more fun so ;)
Once again! I hope it's okay that I write in englist smile
06.08.05 14.57
DasWiesel
images/avatars/avatar-537.gif
Herkunft: Riedstadt
The 11S also runs with a 35 PDSI carburator...
LS Flie?heck, Bj: 1969, DZM, Sportlenkrad, kardinal-rot
06.08.05 17.59 DasWiesel ist offline E-Mail an DasWiesel senden Beiträge von DasWiesel suchen Nehmen Sie DasWiesel in Ihre Freundesliste auf
Cassius
Original von DasWiesel
It does!? That's good news smile Now I only have to figure out which jets I should use ;)
But what about the cam? Is it the same as the 12S cam or isn't it? That's the only thing I need to know now smile
06.08.05 18.22
DasWiesel
Herkunft: Riedstadt
aww... you can use the jets from the 12S also for the 11S
i'm using the jets from the 12S for my 11N! smile
07.08.05 12.42 DasWiesel ist offline E-Mail an DasWiesel senden Beiträge von DasWiesel suchen Nehmen Sie DasWiesel in Ihre Freundesliste auf
Cassius
But are you running two carbs?Since the 11S and 12S uses the same type of carbs I was thinking maybe I'd weld a new intake and build a 11SR copy! :D But should I run the same jets as in the 12S carb for example? Thats sounds like an awful lot of fuel for a pretty small engine! :S
While were on that subject, does anyone know which jets the 11SR uses? That would help alot smile I've read through the forums a bit and it looks like the 11S, 11SR and 12S uses the same cam so..
07.08.05 12.59
DasWiesel
Herkunft: Riedstadt
no I#m running 1 carburator...
if you rebuild a 11SR, you need 2 carbs, with different jets like the jets from one carb of a 12S...
07.08.05 13.07 DasWiesel ist offline E-Mail an DasWiesel senden Beiträge von DasWiesel suchen Nehmen Sie DasWiesel in Ihre Freundesliste auf
DasWiesel
Herkunft: Riedstadt
so where do u live in sweden?
i'm going to go to sweden tomorrow erfreut
spend my holidays in smaland... :r)
07.08.05 14.55 DasWiesel ist offline E-Mail an DasWiesel senden Beiträge von DasWiesel suchen Nehmen Sie DasWiesel in Ihre Freundesliste auf
Cassius
Now I follow ;) thanks for the info! :D
yup, I'm from sweden ;) But not smaland, I'm from the northern part of my loong country (Skelleftea, it's about 100 miles north of stockholm) :D Hope you'll have a nice holiday and that the weather holds up! It's been raining down south for most of the summer unfortunatly..
07.08.05 15.47
DasWiesel
Herkunft: Riedstadt
no problem... ;)
its mad that you're not living in smaland... otherwise we could meet mad
yeah hope the weather will be nice... Top
07.08.05 16.09 DasWiesel ist offline E-Mail an DasWiesel senden Beiträge von DasWiesel suchen Nehmen Sie DasWiesel in Ihre Freundesliste auf
Cassius
hehe, well smaland is a nice place ;) And if I had lived down there it would have been nice to talk about old opels with someone smile
07.08.05 18.10
1000er
Herkunft: Wien
hi!
if you want to use two solex carbs, it's like thze 1,1SR engine.
look at this list to get the right jets for the carbs:
08.08.05 19.59 1000er ist offline E-Mail an 1000er senden Homepage von 1000er Beiträge von 1000er suchen Nehmen Sie 1000er in Ihre Freundesliste auf
