How to lower my kadett? |
Opelkadettb1967 unregistriert
Hi, I wonder how to lower my kadett 67 both front and rear?
or is there lowering "springs" for them to buy? If so anyone know where?
12.06.08 00.07 |
hecktriebler
Olympia A
Herkunft: süddeutschland
| RE: How to lower my kadett? |
hi
here are some threads for lowering the front/rear-axle:
Welche Blattfeder
Frage zur 60er Lenk Blattfeder
there are still merchants who sell springs for kadett-b.
there is also a 'block' available which fits between the (original) front spring and the body of the axle. the effect is that the spring will be pressed down by installing it. but people say that the driving-behaviour of the car will get worse with it. so this is cheap, looks good, but driving will be less nice.
needful to know is the type of your kadett. has it ohv or cih? if you have a ohv, the effect of lowering (e.g. with a 'lenk' lowering spring) will be smaller than with a cih-model because of the weight of the engine.
greez
oli
__________________ ... mir nach, ich folge Euch
http://www.hecktriebler.ch.vu
12.06.08 10.21 |
or the other way you put some Sack Zement in your Kofferraum
12.06.08 17.24 |
- or you let some Luft aus the Reifen
26.09.09 11.29 |
wärri naiss....
26.09.09 11.31 |
häh,
Reifen stören beim Lowering extremst - Felgen reichen vollkommen aus.
Reifen sind überbewertet, oder?
26.09.09 17.06 |
