--- 8x13 ats classic, wheels fitted page 2 (https://archiv.kadett-b-forum.de/thread.php?threadid=11455)
Geschrieben von mawatip am 12.10.08 um 20.52:
dear kammiz, are you trying to kid us - you can´t really think of cutting of the wishbone flesh at its edge
Just take the good old(school) fender extensions or (better) choose a reasonable rim-tyre combination.
Geschrieben von Lallas Garage am 12.10.08 um 21.00:
Hallo ich bin der neue
8x13 mit 175/50 nur kanten umlegen...
Geschrieben von kammiz am 12.10.08 um 21.02:
thank you for your answer. i have allready tried to fit the wheels, but they dont fit on the inside. i will use some distance plates i think. that is the safest way. i will only need 5mm.
i have a wheel arch roller, so i can make the "kotflugel" wider also.
Geschrieben von kammiz am 12.10.08 um 21.05:
Original von mawatip
Just take the good old(school) fender extensions or (better) choose a reasonable rim-tyre combination. |
i am just trying to figure out what "baker1959" means by this:
Original von baker1959
some body work at S-frame behind front wheels are needed.
Also the tires will scratch at rear inner fender when the car is fully loaded.
baker |
Geschrieben von kammiz am 22.10.08 um 10.22:
a 5mm spacer was the smartest solution and it seems baker1959 cannot give me a explanation for how to modify the s-frame, so i guess he realized it was a bad idea.
Geschrieben von baker1959 am 22.10.08 um 20.28:
look...idea is a lttle bit tricky.
If you prefer quick and dirty, catch a sledge hammer and snuggle the frame.
Geschrieben von kammiz am 23.10.08 um 09.15:
is this really necessary? i have mounted the wheels and they dont seem to touch the s-frame, even though my car is slammed to the ground.
